1978 - 1996 Big Bronco
Tailgate Problem
Old Nov 27, 2001 | 08:47 PM
Luke Peterson's Avatar
Luke Peterson
Tailgate Problem
I have an 1984 XLT. The window will not go up or down when I turn the key on the tailgate or when I use the switch on the dash. The window will go up and down when I press on the top middle-right of the tailgate.The tailgate is shut. Is this a torsion bar problem because I hear a grinding noise when the window goes down for the final couple of inches and up for the first couple? Anyone have any ideas on how I can fix this problem. Thanks
Old Nov 27, 2001 | 10:09 PM
Bob_VT's Avatar
Bob_VT
Tailgate Problem
First do a search on tailgates on this section of the message board.
I would climb into the back of the bronco and remove the access panel. Check the torsion bar where it goes across the inside of the tailgate. The common place for the bar to tear loose is on the drivers side. The bar should be difficult to see when you look in because it "should" be along the sheet metal inside the tailgate.
If it is the torsion bar get it fixed or fix it ASAP. I used a large U-bolt (actually it was a U-bolt from a cable clamp) to tie the end of the torsion bar back into place. This was a result of having a window explode from the torsion bar pressure on it.
There is also a window limiting switch and lockout switch in the tailgate. However due to the grinding sound you describe I would check the torsion bar.
Old Dec 13, 2001 | 10:58 AM
dragonman's Avatar
dragonman
Tailgate Problem
Luke, I was wondering if you were able to find out the cause of your tailgate problem. I have an 89 Bronco and was expeiencing the same problem with mine.
thanks
dragonman
Old Dec 21, 2001 | 09:00 PM
Franklin2's Avatar
Franklin2
Tailgate Problem
Old Dec 26, 2001 | 07:00 AM
Luke Peterson
Tailgate Problem
I fixed the problem. It was with the tailgate latch on the left side. The left would not close the circuit all of the time. So when I pushed on the tailgate it would close the circuit and work. I worked on both of the latches. I cleaned them out with WD-40 and then greased them up and really worked the grease into the latches. I also greased up the handle mechanism. I also stripped the rust of the interior tailgate, primed and painted it. It looks good and works now. Hope this helps.
Luke
peganit2
17
Jan 9, 2014 05:58 PM
Tim Hodgson
Jun 10, 2013 04:34 PM
TicoTube
19
May 3, 2013 03:03 PM
brocobilliam
Nov 6, 2004 12:56 PM
79GreenMonster
Apr 6, 2002 11:34 AM
