cab changeover
Old Apr 12, 2007 | 09:47 PM
nitronigs's Avatar
nitronigs
cab changeover
Hi,
I have a non-ac cab on my truck now with a 300 six 4 speed tranny 4 wheel drive and i want to change the cab over to a a/c cab from a truck with a 351 auto 2 wheel drive, what work will it be to make this conversion to accept my drivetrain for the air to operate properly?..........thanks Jeff
Old Apr 12, 2007 | 10:36 PM
Ultramagdan's Avatar
Ultramagdan
If it's the same year of cab I would expect the biggest challenge is converting the auto cab over to a stick. Getting the clutch pedal in may be a big challenge. That, and the 4X4. Not impossible, just a lot of work. The AC should be the easy part although you may need to move components around so your motor is set-up appears stock.
This is going to take some work.
Old Apr 16, 2007 | 01:12 PM
nitronigs's Avatar
nitronigs
Hi,
Would the cab floor height be any different from 2 wheel to 4 wheel drive for the four speed and would the rad support and radiator be any different for my six cylinder motor and for the a/c cooling capacity?..........thanks
Old Apr 16, 2007 | 08:37 PM
Ultramagdan
The cab height should be the same and you will need to check and see what the other one had in it for a rad. Now's a good time to get a tape measure out.
Jeff and Nicolle
Nov 30, 2010 12:57 PM
jeff gammon
Aug 4, 2009 11:56 PM
minkman
Sep 7, 2004 10:05 AM
2 cowpokes
Car/truck Buying Advice
Jul 16, 2004 06:43 PM
jmotter
May 22, 2003 06:41 PM
