turn signal/hazard problem
Old Apr 12, 2007 | 07:13 PM
taagerlach's Avatar
taagerlach
When my steering wheel is in the full up postion my right turn signal and hazard light work fine, when i adjust my steering wheel down is quits working on the right side. I changed bulbs and no fix. Any ideas or suggestions
Old Apr 12, 2007 | 07:31 PM
cddz's Avatar
cddz
is it the dash light only? or is it the actual turn marker lamps also? sounds like a loose connection on the clock spring
Old Apr 12, 2007 | 08:30 PM
elite64a's Avatar
elite64a
I have heard this before on the site the problem if my memory serves me right was whenever you adjusted the wheel down it was puling the connection loose therefore making it useless just do a search you should be able to find it in here
Old Apr 14, 2007 | 11:17 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Probably one of the pins has pulled loose out of the multi function switch connector.
Remove the multi function switch, and closely examine the female terminals in the wiring harness connectors. Look for one that isn't "locked" in place.
good luck
