Modular V10 (6.8l)
odd rattle
Old Apr 12, 2007 | 06:39 PM
mont974x4's Avatar
mont974x4
odd rattle
2003 F-250 V-10 Auto 4x4
84,000 miles
Since I have been trying to keep my RPM's down under 2 grand (seeing how that helpls mileage) I only hear it real softly about 1700 RPM. However, when I drive like I want to it's loud and starts at 1700 RPM and goes until I either let off or the tranny shifts.
It sounds like a metalic rub/swish/rattle sound. I don't have a way to make a sound clip.
Is it the inspection cover on the bellhousing? It seems ford would have put a bolt in the bottom of it but there isn't a space for one. I checked the other two bolts and they're good.
Catalytic converter clogged? Every so often it won't start. It'll turn over and act like it's starting but it run for a second or two then shut down. Also, when it's cold out every so often I get a high pitched whine squeel from under the front half of the truck somewhere. It's not a belt, has a different sound to it I have not heard before in my other trucks.
Thanks in advance for any input.
Jay
Old Apr 12, 2007 | 06:42 PM
boxcar1974's Avatar
boxcar1974
The noise is the bell housing dust shield and the IAC is the most likely cause for the starting and shutting off issue.
Bend the dust shield a bit or put double sided tape (take the backing off one side) on the shield to cushion it. Clean or replace the IAC for the idle problem.
Old Apr 12, 2007 | 06:44 PM
mont974x4's Avatar
mont974x4
Other than that it runs great. lol
ok, I'll make a trip tomorrow for a new IAC and some tape.
Thanks
Jay
Old Apr 13, 2007 | 10:02 AM
bigunred's Avatar
bigunred
the start up whine is most likely the power steering pump. try sawing the wheel back and forth at start up and let us know. ive had this problem on 2 exs and an SD.
Old Apr 13, 2007 | 10:12 AM
mont974x4's Avatar
mont974x4
p/s pump? how the heck does that happen?
Old Apr 13, 2007 | 11:41 AM
kanertop's Avatar
kanertop
My guess for the rattle would be a heat shield on the exhaust pipe located before the cat. Check the crappy spot welds. I bet one or two have failed causing a vibration at certain RPM.
Old Apr 13, 2007 | 03:43 PM
boxcar1974's Avatar
boxcar1974
It is well know the torque converter heat shield rattles like mad between 1700-2100 rpm on V10's. Notice how the shield is mounted with two bolts on the side and the shield fits outside and inside on top and bottom. Remove the heat shield and drive it around. If the noise is gone....bingo.
Old Apr 13, 2007 | 04:36 PM
mont974x4's Avatar
mont974x4
spot welds have held so far. A few days ago I tightened the two bolts on the tranny inspection cover. No dice.
This morning I got some double sided body tape, backed off one of the bolts and attached a short piece to the tin. No more rattle.
I was given a good idea today from a neighbor. He suggested the cork gasket material.
I want to keep the shield because I do get into deep snow etc when hunting.
Old Apr 14, 2007 | 12:04 AM
Monsta's Avatar
Monsta
Sit. Stay.
Ford says it is a normal thing when it is cold out. Some have helped reduce the sound by replacing the fluid with a synthetic fluid.
Old Apr 14, 2007 | 10:44 AM
mont974x4's Avatar
mont974x4
Ohh, the whine isn't at start up. It's after I have driven. Sometimes it's while I am stopped and sometimes when driving but at low speed (10 mph and under). I haven't oinned down what conditions it happens in any further than that yet.
Old Apr 14, 2007 | 01:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
Check your PS fluid anyway.
Old Apr 14, 2007 | 06:21 PM
mont974x4's Avatar
mont974x4
Who makes synthetic p/s fluid?
I'm thinking of changing all my fluids to full synthetic. Royal Purple maybe?
Old Apr 14, 2007 | 08:48 PM
lariat97's Avatar
lariat97
Whats up Jay? I see your over here looking for advise. You couldn't have made a better choice for info. FTE has the best info on Ford trucks on the net. Good to see you here.
Old Apr 14, 2007 | 09:05 PM
mont974x4's Avatar
mont974x4
Hey, Howard? I forgot I joined here a few years ago and since FTW is all jacked up as of late and I needed help, well, here I be. lol
Give the missus our love and prayers.
Jay
Old Apr 14, 2007 | 10:17 PM
lariat97's Avatar
lariat97
FTE is a good site. Its the place to go if you need good advise on truck repairs. Lisa says hello. I'll be watching for you around here now.
