Bumper trouble - Help!
I have attached two pics to illustrate where the bumper is cracked - it is right next to where it attaches to the front fender... just forward of the wheel well. The splash shield has a straight crack through it as well. I brought it to a local bodyshop that "bonded" the crack but it is still visible from the outside. What would need to be done to fix it so the crack is no longer visible (if possible?)? Ballpark of what it would cost? Would any of you guys actually bother to fix it if it was your rig or would you just leave it as is? Also, when I grab the bottom of the bumper cover and pull up the whole bumper cover can flex/move up about 1/2 or 3/4 of an inch - is this normal?
https://www.ford-trucks.com/user_gal...id=148134&.jpg
https://www.ford-trucks.com/user_gal...id=148133&.jpg
Thanks in advance,
Bob
https://www.ford-trucks.com/user_gal...id=148229&.jpg
https://www.ford-trucks.com/user_gal...id=148230&.jpg
