I'm planning on going the DP tuner route, but am looking into gauges first. I like the idea of a compact digital display over a pillar full of gauges. I was wondering if the Attitude could be run by itself just as a monitor, or if their are any other resonably priced digital displays out there.
You will need the Juice module to make use of the EGT and Boost monitoring, You could get the New Evolution....its the same except it comes with a egt harness for that part and then just plugs to the Diagnostics port to monitor the rest. That way is kinda spendy especially since you are gonna go with the dp tuner, then there is no sense in haveing the Evolution. I have seen some Digital guages that can monitor sever paramaters......you might want to check out the major gauge manufacturers.
Quadzilla has one. its ok. but now that i have it I am not going to change it. but probably would have gotten sparate gauges. but its all point of view I think.
