1978 - 1996 Big Bronco
Rear rain gutter fix
Old Jan 4, 2002 | 07:17 PM
Bakes5's Avatar
Bakes5
What have y'all done to fix your rain gutters where they crack at the rear. I sanded and painted it then put some RTV sealant on it last year as a temporary fix, but figure I need to fix it right one of these days. I heard somewhere ford has a part number for the fix. Anyone know what is in the "fix kit" and how much it costs? Thanks
Old Jan 4, 2002 | 07:28 PM
8996EBBroncos's Avatar
8996EBBroncos
I'm too lazy at the moment to search for the link, but if you will look to the right of this board, it will list a topic called recalls/TSB. Click on that and put in your info about your truck and it should pop up. You will have to scroll through till you find it, but it is there. I read about it last night.
Old Jan 4, 2002 | 07:55 PM
AlM's Avatar
AlM
yo,
here is the TSB:
http://mybigbronco.com/uploads/TSB962010.jpg
thanks to Ford Blue!
someone wrote that a quote for both sides was $800.00
some just seal the cracks with clear silicone.
Old Jan 4, 2002 | 10:20 PM
restorit's Avatar
restorit
Before I knew that this was a common problem, and that Ford had a repair kit, I had mine welded as I already had the roof and gutter area sanded for a repaint. I was able to grind the welds smooth without the need for any additional body filler. So far it's holding just fine.
Old Jan 5, 2002 | 01:11 PM
8996EBBroncos
[updated:LAST EDITED ON 05-Jan-02 AT 02:11 PM (EST)]Does anyone know how to prevent this from happening? I have same problem with my 89, but not so far with my 96.
Old Jan 5, 2002 | 01:13 PM
8996EBBroncos
