Ditch it or build it?
However, it's practically worthless as it stands due to paint in bad shape, lots of rust spots, broken transmission ... it's tired, let's face it. It has 120k so I somehow understand it. I could repair it for 500$ and ditch it for 2-3000$cdn, 4000 tops. I've done so many repairs lately I'm wondering what else can go wrong. I've overhauled the driveshafts and half-shafts, front diff, front brakes and bearings and rear leaf spring hangers, radiator ... those are the only things that come to mind right. Of course I recently got new tires and shocks too.
So here I am, thinking about what I would need to make it good for me.
First off, the auto trans has to go. I can handle the manual conversion, all I need is a trans (800$ ... but I can sell the repaired auto for that price), flywheel (?), clutch, clutch master cylinder, pedal, neutral switch bypass and the proper engine computer. Figure 500$ for all these if found left and right in scrapyards and such? Bit more? Not really sure.
The engine has 120k, but still runs like a charm. Wouldn't tinker with it just yet.
Rejuvinating the suspension is a must, will obviously lift it while I'm there. Tuff Country makes an affordable 4" (400$), but I'm unsure of the extra wheel travel (I need a lot more than right now!). Camburg has a 10" travel (still 4" lift) for 1600$ ... would have to make sure it's worth it!
Annoyingly enough, I have the 3.27 open diffs and the rear is calling for an overhaul... wouldn't hate going to 3.73 lockable or limited slip.
I'd love to widen that stance, maybe the long travel i-beams up front and spacers in the back ... not sure I want to change the whole axle back there.
The body is awful right now. Gay powder blue with silly pinstriping, clearcoat is peeling off on the roof, hood and tailgate are rusted big time. Would love going to a prerunner look with wider fenders, but I'm not ready to shell out 300$/400$ for f/r fiberglass fenders ... especially considering the fenders are the only un-rusted body panels!
Any other option for me out there?
Oh yeah, I need some clear headlights, not the ricer thing, my headlights have turned completely dull with time.
That and a neat charcoal metallic paintjob would get it back looking nice, even if it doesn't sport the prerunner fiberglass fenders ...
Interior ... just need better sound system, nicer steering wheel and nicer seats, but other than the sound, it's ok. I'd love to add electric windows too! I have power seats and power mirrors but no power windows. Weird.
There, you now have the whole picture.
So, should I dump it or spend some $$$ and keep it?
You've already spent a lot in it though, and if it's in good shape other than the tranny, get rid of that thing, lift it, and go from there. Depending on how things go, I'm about to slap on a 9" lift with 35"s on mine. It's a good bit of money for any lift beyond 2" or so though.
Sound system can get expensive. Mine's around a grand, but it sounds absolutely wonderful.
As for the manual swap. You'll need a tranny (obviously) for your engine (bolt patterns are engine specific), driveshaft, new floor panel (or cut the old one), shifter, manual pedal assembly, clutch master cylinder, reservoir, slave cylinder, all lines, clutch, flywheel, flexplate, and bearings. I believe the crossmember is the same for both trannies.
I assume you'll go new for clutch kit, and frankly you'd be stupid to use a used slave cylinder, so I'd say at least $500 for the tranny parts to do the conversion, even using a boneyard as much as possible. Tranny is $800 as you said or so.
The Camburg kit is good, but pricey. What would you do for wheels and tires? Those get expensive quick. Don't forget an alignment! New gears aren't too terribly expensive, especially if you do your own labor. Will require recalibrating the speedometer by changing out the gears, but you'll have the tranny out anyways, so why not?
Keep it and play with it!
About the manual conversion, oddly enough I already have the hole in the floor, with a nice oem plate bolted in, so that's gonna be one easy part.
About the pedals ... is it the same pedal holding bracket thingie? ie, do I just need to go under there and bolt the clutch pedal in, or do I have to change the whole assembly? I could always go and check it tonight ...
Wheels and tires, probably 32-33", 10.5" wide, no more. I'm a reasonable guy when it comes to tires, I'm not lurking after some 39" Boggers
. I wouldn't mind going to 16" wheels (only because it looks better!), but my current 15" will do just fine. I'm not really counting them in the equation because even if I change trucks, I will be getting new and larger tires
I know Camburg is expensive ... but damn are those parts beautiful! I'd leave them in my living room!
What annoys me is that all the money I'll put into it is money right down the drain, I'll never see it again. There again, since I'll do all the job myself, it's just parts.
http://www.classic36pickup.com/
It is my hope for my current one.
!!!! Have you gone throught the pricing thing?
!!!! Have you gone throught the pricing thing?Trending Topics
But I'm more going for a look like this
After seeing this pic, I'm pretty sure everyone is gonna say to go for it ... but I'm getting a bit scared by the price though. An easy 2 grand on suspension + 1000$ for body ... kinda youch.
But at least, I'd have a pick-up, manual and competent offroad. It appears suspension will be the most expensive as a wider stance appears ever more important if I want to stay away from the "stock but lifted" look.
If not, I can dump it and get a TJ instead.
That's just a pic stolen from the interwebz to illustrate what kind of setup I'd love to end up with ...
... I know there's far more than 3k in upgrades, but I'm not necesserily going to such a level either, that's just inspiration!1600$ gets a 10" travel Camburg up front, and another 500$ is a match for the back. It will be PLENTY for the terrain we have (nothing quite as fast as desert). I will never need rear traction bars, for instance!
Body, I said a grand because just the fenders are 700$
You're right about re-gearing ... did I mention it has 3.27 open diffs?
. Wish I knew how to look it up when I bought it.mmmh, I'm starting to think this truck will need far too much money to make this work.
