5 leafs to four
Old Apr 11, 2007 | 04:58 PM
Okiedokie's Avatar
Okiedokie
5 leafs to four
Ok I am looking for that sweet spot fenders found. I now have four long leafs and one short one. Remove the short one, or one of the long ones?
Old Apr 12, 2007 | 07:34 PM
Fomoko1's Avatar
Fomoko1
Can anyone help?
Old Apr 12, 2007 | 09:42 PM
John - NNY's Avatar
John - NNY
Whoaaaa!
Sorry I can't answer that one but it got me thinking about my spring set up. . .
Old Apr 13, 2007 | 07:04 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Whoa! Got springs? I thought my 13 leafers on my F-3 were big!
Old Apr 13, 2007 | 08:45 AM
fatfords's Avatar
fatfords
Joe,
I can't remember what set-up 'Fenders was running on his 53 but I did find the recommendations in the Mid-Fifty catalog. "Starting with the shortest, keep #1, remove #2, keep #3, remove #4, keep #5, remove #6, keep #7 but cut off the wrap 1 1/2" from the eye. " With reversed eye springs this is supposed to drop the rear 3 to 3 1/2".
Assuming that you followed the above or something similar, it would depend on what you want and how the truck feels now.
If the ride is already soft, I would remove the short one to drop it a little more but maintain as many long springs as possible.
If the ride is still too firm, I would look at removing one of the longer ones as this will tend to soften the ride. I would not remove the spring immediately under the main spring (#7 above).
Hope this helps.
Good Luck!
Old Apr 13, 2007 | 11:27 AM
Okiedokie's Avatar
Okiedokie
Thanks Kent. I did follow the Mid Fifty recomendation originally. Then I removed one more to have 5 leafs. Ride heigth is ok, ride could be softer. I guess I will remove one of the longer ones and see what results. Joe
Old Apr 13, 2007 | 11:31 AM
imlowr2's Avatar
imlowr2
I would remove a mid size one or the other one from the bottom. I'm running 3 in my 56 and the back end is still stiff and a nice ride. I had 2, and that made it a little bouncy. With running on 3, I wanted to keep as many long leafs as possible to give the main spring more support, they tend to crack if your lacking support there.
Joe, removing the leafs will soften the ride up. If your concerned about ride height, you can always add a spacer plate in. In otherwords, you can run 3 leafs, but to keep your ride height, put a spacer, similar to lowering blocks in and that will keep your ride height up but still allow you the softer ride. Good luck.
Old Apr 13, 2007 | 03:12 PM
Okiedokie's Avatar
Okiedokie
Thanks imlower2, that's my plan now. Remove the one "mid size" leaf now in the pack and add a spacer to retain heigth. Joe
