Bronco II Ford Bronco II
86 bronco II-electrical
Old Apr 11, 2007 | 01:31 PM
leftfield's Avatar
leftfield
had a post broken on solenoid.replaced it,but hooked new one up wrong.replaced it,but now i don't even have accessory lights when i turn on key.what did i fry?
Old Apr 11, 2007 | 03:58 PM
mrshorty's Avatar
mrshorty
Have you checked the fusible links to see one or more of them blew?
Old Apr 11, 2007 | 04:34 PM
leftfield's Avatar
leftfield
not yet.i'm on the road and will get to it saturday.just wondering where to start.
Old Apr 12, 2007 | 05:17 AM
kernel-panic's Avatar
kernel-panic
check the fusible links. I can't remember if there are two or three off the top of my head, but all of them should connect to the battery side of the starter solenoid, and you should have continuity between the terminal end of them and the wire that they connect to for each. You may also want to check all of your fuses in your fuse panel, etc., as well as the connector(s) for your key switch.
Old Apr 14, 2007 | 11:41 AM
leftfield's Avatar
leftfield
also,i can jump across the solenoid and it will start,but when i remove jumper,it dies.
Old Apr 14, 2007 | 12:38 PM
steve87_gt's Avatar
steve87_gt
If memory serves, their are THREE fusible links right there near the solenoid.
Old Apr 14, 2007 | 04:18 PM
kernel-panic
And all three should be on the BATTERY side of the solenoid. If you have any other wire besides the heavy cable that goes from the solenoid to the starter on the starter side of the solenoid...
