power issue
Old Apr 11, 2007 | 06:53 AM
mexemo's Avatar
mexemo
power issue
I have a 97 f350 drw 4x2 ext cab with 64,500 miles.I love the truck,but it doesn't seen to pull strong enough(power).I am pulling a 35 foot 5th wheel camper weighing 12,400 dry and then our goodies.
The oniy mods are down pipe,exhaust,diy intake,and rebuilt trans.Truck runs great!!!! I just think it should pull better.
I also have the 3 guages,but haven't installed yet.
Any insight would be thankful.
THNKS,MEX
Old Apr 11, 2007 | 07:34 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Get a custom chip from Tony Wildman or DP Tuning and bigger injectors. If you get the chip or injectors, it's a MUST that you install the gauges to monitor everything.
Old Apr 11, 2007 | 09:19 AM
ltfox's Avatar
ltfox
Thats a big load, might be expecting too much????
If ya do want more power...plowhands right on!
Old Apr 11, 2007 | 09:53 AM
97-7.3dump's Avatar
97-7.3dump
IMHO 12k+ is not a big load for these trucks. It may take a little longer than you want to get up to speed but you'll get there and maintain it. I gross out near 30K routinely with no problem except it takes longer to get to speed than I would like.
Running a straight exaust made a big difference in EGT's and helped with power for my '97. If you run a chip while towing you absolutely need gauges to keep things within safe parameters!
Happy towing!
Old Apr 11, 2007 | 10:05 PM
mexemo's Avatar
mexemo
I went out and shimmed the fpr and done the 10k mod.
Mods went well and truck run a little better.
Thanks for info
