1978 - 1996 Big Bronco
warning buzzer in 92
Old Jan 10, 2002 | 08:24 AM
hermann's Avatar
hermann
Hi, I must scream. My warning buzzer in my Bronco
donīt stop "ping ping ping". Has anybody an idea how can
solute this problem. Now Iīve removed the buzzer .
Thanks Hermann
Old Jan 11, 2002 | 01:41 AM
cyberdr2's Avatar
cyberdr2
There is a ring inside the ignition switch (gold if I remember correctly) that when you turn on the ignition it makes contact. This ring is either broken or has moved causing it to short on something. I had the same problem with my other Bronco. I got lucky and saw part of the ring sticking out and pulled it out the rest of the way with a pair of needle nose plyers. The ring was located just behind the silver key cover. Hope this helps.
Old Jan 11, 2002 | 11:21 AM
adelyser's Avatar
adelyser
