Trany Temp
Old Apr 10, 2007 | 09:23 PM
BIGFISH70's Avatar
BIGFISH70
Trany Temp
What is a good trany temp? I put my Edge in but I am watching the trany temp but I don't know what a good one is.
Old Apr 11, 2007 | 06:46 AM
Tom's Avatar
Tom
That's already been discussed here.....
https://www.ford-trucks.com/forums/5...s-damage.html?
Old Apr 11, 2007 | 01:02 PM
osteodoc08's Avatar
osteodoc08
Mine usually runs between 140's to low 150's. When I tow my 2 jetskis it has been no higher than the low to mid 160's.
Old Apr 11, 2007 | 01:36 PM
gui88ford's Avatar
gui88ford
i think if you hit 220 then you may have problems if it stays at that for a little while....like osteodoc08 says....140 to 150 i think is the norm here...
hope it helps...
Old Apr 11, 2007 | 03:32 PM
BIGFISH70's Avatar
BIGFISH70
Thanks, for the info this will help alot. Do you guys take your truck out of OD when pulling?
Old Apr 11, 2007 | 04:24 PM
osteodoc08's Avatar
osteodoc08
I take mine out of OD.
Also, now that it has been in the upper 80's and lower 90's here in FL, my tranny gauge has gone up a little, but hasn't past 170 yet. On the highway this morning it didn't pass 155 and I have an hour long commute. It usually settles in around 150 with cruise on at 75mph.
Other things I look at on a regular basis
Voltage: 14.1-14.3 when cruising
Coolant temp: 192-196 when fully warmed up
Tranny temp: 145-170
Fuel pressure: 39-41psi
IMPG: depends on position of the skinny pedal
