Lightning rims
Old Apr 10, 2007 | 08:33 PM
gearheadib's Avatar
gearheadib
Question Lightning rims
I have a 1983 F 150 I want to put some 04 or 05 ford lightning rims on it. I need to know if they have the same bolt pattern, and will fit?
Old Apr 10, 2007 | 10:00 PM
Franklin2's Avatar
Franklin2
I don't think they will fit. The old trucks have 5 on 5.5 or 5x139.7mm. The later trucks have 5x135mm bolt pattern.
Old Apr 13, 2007 | 04:27 PM
gearheadib's Avatar
gearheadib
Thats only 4 mm. A well placed drill bit shoud do the trick for that.
Old Apr 13, 2007 | 04:36 PM
Boss50's Avatar
Boss50
I have seen '97 F150 rims on an '85. I've seen quite a few around here mis-matched like that. They must fit.
Old Apr 13, 2007 | 07:06 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
No they will not the 83 is 5x5.5 pattern and the 97 up is 5x135mm I had a set of lightning wheels I was going to put on my 86 and they don't fit. They did however make a aftermarket replica in the old lug pattern.
Old Apr 13, 2007 | 07:56 PM
gearheadib's Avatar
gearheadib
thanks for all the info
Old Apr 14, 2007 | 05:39 PM
lostin90s's Avatar
lostin90s
They don't fit . But not by much . But I don't mess with wheels when it comes to that. I suppose you could get them machined but with the liability I don't think you find anyone to do it. Good luck
