Pcm?
Old Apr 10, 2007 | 07:01 PM
Benny2002's Avatar
Benny2002
Question Pcm?
Does anyone have a pic of a 2002 PCM? Or does anyone know if all of them have CAT-5 E data port on the side?
Old Apr 10, 2007 | 07:36 PM
Uzumati's Avatar
Uzumati
PCM doesnt have a CAT 5 port I think the VSM does though.
Old Apr 10, 2007 | 07:38 PM
Benny2002's Avatar
Benny2002
vsm : what is that? anyway i was fishing around under the fuse panel in the cab and found a cat 5 wire cut and the end was stuck inside what i thought was the brain guess not vsm? I think for a short time the previous owner had a programmer but not sure? is that where they plug in?
Old Apr 10, 2007 | 07:47 PM
Uzumati's Avatar
Uzumati
The PCM is down behind the Park brake pedal in a metal box in a plastic mount up against the firewall. I would guess that was an old alarm system
Old Apr 10, 2007 | 07:54 PM
Benny2002's Avatar
Benny2002
What is the vsm?
Old Apr 10, 2007 | 08:02 PM
Uzumati's Avatar
Uzumati
Vehicle Security Module
These are the Modules it can contain
4- wheel anti-lock brake (4WABS) control module (if equipped)
vehicle security module
overhead trip computer (OTC) (if equipped)
restraint control module (RCM)
air suspension control module
4-wheel drive control module
instrument cluster
It is located behind the Radio
Old Apr 10, 2007 | 08:09 PM
Benny2002's Avatar
Benny2002
Its about 5 inches by 11 inches. It has what looks to be a coax type cord coming in one side with a big connector with lots of pins and two side set screws for that connector on the same side and then on the length side it has the cat 5e port. It says motorola on it but thats about it. I found it under my fuse panel cover, not behind the radio. Does this sound like it? Any thoughts on why it would be there if its normaly behind the radio?
Old Apr 10, 2007 | 08:12 PM
Uzumati's Avatar
Uzumati
If it says Motorola on it I would bet it is a cellular hands free kit
Old Apr 10, 2007 | 08:18 PM
Benny2002's Avatar
Benny2002
SWEET now i know what the mic on my pillar is for, now i just need to figure out how to hook it up again. Thanks alot Alan, that mic has been bugging me from day one, its really small and i know its got a long cord somewhere in my headliner or my door post, it was done well so i havent pulled it all apart. Now i just have to find what parts its missing.
Old Apr 10, 2007 | 08:23 PM
Benny2002's Avatar
Benny2002
i know that "chips" are installed inside the pcm, where does a programmer hook up to? The 4 wires or so coming out of the big harness near the firewall?. I have 4 wires with shrink tube on the ends, a buddy told me thats where they hook to?
Thanks again for the cell phone info i never put two and two together, i know motorola makes alot of electronic gadgets, never even thought phone
