What is a PCM? I did a search and got "no matches". I'm asking because the Ford guy said I probably need a new PCM seeing as the pressure coming off the schraeder valve is not registering. It could be air getting in somewhere in the fuel line, but I'd like to look into this PCM thing as well.
-I think he said PCM. He was foreign and I'm not exactly certain that was what he said. No offense to any foreign born FTE's.
Unless your truck is a powerstroke the pcm has nothing to do with fuel pressure in fact most of the 7.3l powerstrokes still had mechanical fuel pumps on the engine.. there is nothing wrong with your pcm there is something wrong with your mechanic.. first thing I would do if I were you is fine a new Mechanic...
