1966 - 1977 Early Broncos
Power Steering
Old Apr 10, 2007 | 02:09 PM
bawrestler's Avatar
bawrestler
Power Steering
I have a 67 bronco that Im building and was wondering what a good power steering setup would be. I don't need anything too extreme Im not doing any rock crawling just some mudding and dunes with 35's or 38's.
Old Apr 10, 2007 | 06:01 PM
bigperm2's Avatar
bigperm2
I used a nissan pathfinder box with a GM "canned ham" pump on mine and I love it. It probably took a full weekend to do the swap. I don't have a long time to type right now, but basically, the 3 holes on your stock manual box almost match the 4 holes on the nissan box. I drilled the frame, and used a stiffener and bolted through the 4th hole. I then had to make a custom drag link with a heim joint with the stock nissan pitman arm. If you do a search on the web, I am sure you can find pictures. I think a lot of people weld the bronco pitman arm to the nissan arm, but I am not a fan of welding cast iron, especially unknown and probably different iron properties. If you are interested in going this route, I can give you some more information!
