1998 ford explorer runs rough
Old Apr 10, 2007 | 12:40 PM
job247's Avatar
job247
Question 1998 ford explorer runs rough
I have a 1998 ford explorer with a 4.0 single over head cam with around 130000 miles. It runs rough or sort of misses when heald at an even speed around 35-40 mph. It also runs rough for a few seconds when first started when cold out. I replaced the spark plugs and wires. I thought it may be the intake gaskets since I have read that is a common problem area. I replaced the upper and lower intake gaskets and still same problem. I have also cleaned the mass air flow sensor. I hooked my obd ll testor up to it and no error codes showing. Any ideas??? Also I have enjoyed checking out other posts in here and have learned a lot...Thanks
Old Apr 11, 2007 | 02:51 PM
RoziBud's Avatar
RoziBud
Ive got the same thing happening to mine as well....
Mine has about 108,000 miles on it.
Its a 98 XLT......
The transmission is doing something funky too.....Glad I only live 3 blocks from the office haha
Old Apr 11, 2007 | 03:08 PM
merlynr's Avatar
merlynr
You sure it's not the transmission "hunting for proper gear" My 99 does it sometimes at around that speed, but conditions have to be just right. Does it do it in straight drive or overdrive?
Old Apr 11, 2007 | 08:12 PM
luvmyford's Avatar
luvmyford
I had a similar issue with my '97 4.0 OHV. After replacing wires, spark plugs, IAC, and cleaning the MAF and TB, still no difference. A friend of mine suggested that I disconnect the battery for at least 30 minutes. Reconnect and then start the motor BUT do absolutely nothing else (turn the key and walk away) -- just let it idle for about 30 minutes to let the computer relearn and adjust itself. Don't be tempted to rev the engine or put in drive or reverse. The rough idle disappeared completely.
Old Apr 12, 2007 | 10:07 AM
job247's Avatar
job247
Question 98 explorer runs rough
It does it pretty much when it gets above 35 mph. I notice it in town and on the interstate. I notice it most when trying to hold it at an even speed. It seems to have plenty of power on take-off and when getting on the interstate and doesn`t seem to cut out or anything. It is when I drive at an even speed. I have replaced the fuel filter thinking it may dirty, replaced the intake gaskets to eliminate it sucking air from that area, cleaned the mass air flow sensor, replaced plugs and wires, put fuel injector cleaner in the tank and have looked for air leaks but havent found any yet. The transmission seems to shift ok with the usual lag at times when driving around town. Thanks for the replies.
Old Apr 12, 2007 | 10:30 AM
Backin72's Avatar
Backin72
Silly question.......did you use Motorcraft plugs?
Old Apr 12, 2007 | 10:32 AM
job247's Avatar
job247
I am not sure but think they were autolite double platinum
Last edited by job247; Apr 12, 2007 at 10:38 AM. Reason: used wrong word for brand name
Old Apr 13, 2007 | 07:37 PM
job247's Avatar
job247
Just curious....I used an anti-seize compound on the new sparkplugs when I installed them. Would this cause a misfire of some sort? if so what is the best way to remove the compound from the spark plug holes???
Old Apr 15, 2007 | 11:25 PM
RoziBud's Avatar
RoziBud
mIne does it in Straight drive and Over Drive.
Old Apr 17, 2007 | 11:44 PM
job247's Avatar
job247
Someone told me that the EGR valve may be bad. Would this cause it to miss and run uneven? How would I know if it was bad? I have ran out of ideas. Thanks for all the replies.
bchitwood73
Aug 23, 2016 06:05 PM
MikeJ123
3.8 & 4.2L V6
Nov 17, 2015 03:22 PM
bearcat1061
1997 - 2003 F150
Oct 24, 2014 10:17 AM
randy1973
1983 - 2012 Ranger & B-Series
Oct 25, 2011 10:05 PM
Frank_D
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 13, 2009 09:37 PM
