Good Diesel Shop in Central Texas
Trying to put my finger on my problem and looking for a good shop to do it at. I live in Belton, Texas.
"P1316 - IDM codes detected. This can be several things. The main thing is you still have more codes to pull, but they are stored in the IDM itself. Your Superchip tuner cannot retrieve them. You must have a diagnostic tool that can peform an injector buzz test to pull the IDM codes. The cause of these codes can be something as simple as a loose UVC harness clip, or you could have bad injectors or a bad IDM. By pulling the IDM codes, it will point you exactly which injector or bank of injectors is having the issue."
Any info is appreciated.
