3rd gear gringing noise??????
Old Apr 10, 2007 | 10:49 AM
tgowers's Avatar
tgowers
Exclamation 3rd gear gringing noise??????
my truck is a 68 f100, 2wd, 360ci. , 3 on the tree..... while driving down the road in 3rd gear i hear a grinding/ screatching sound that comes and goes(kinda sounds like you are trying to start the engine while it's already running, but it's not that.)..... it's very loud. is it possible that i need to adjust my shift linkages, because maybe my third gear linkage is either not engaging enough, or engaging too much? should i change the fluid in my transmission? has anyone had any similar problems? thanks guys. -tony
Old Apr 10, 2007 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does your truck have a two-piece driveshaft?
Old Apr 10, 2007 | 01:50 PM
tgowers's Avatar
tgowers
it just needed some more fluid....well it was bone dry actually. filled it with fresh 80w gear oil and she is good as new. thanks guys. and yes it is a two piece driveshaft... i greased it really good. have a nice day guys. -tony
Old Apr 10, 2007 | 02:33 PM
dgassett's Avatar
dgassett
that is what happens to me from time to time. I have a leak I can't afford to fix right now. I f I forget to check my levels, i get that noise.
Old Apr 11, 2007 | 07:29 AM
tgowers's Avatar
tgowers
i never had a leak from there so i just assumed it was full. i am glad i checked that since i am going to be taking her out on the interstate for a 2 hour drive to a car show in 10 days.
Old Apr 11, 2007 | 09:52 AM
dgassett's Avatar
dgassett
Nice, you actually drive it to car show? You don't see that to much any more. Well, at least not on the West Coast.
Old Apr 11, 2007 | 01:34 PM
tgowers's Avatar
tgowers
this will be her first real public appearance other than what little driving i have done around louisville.
