Sponsored by: Auxito
question
Old Apr 10, 2007 | 10:36 AM
mojavepa's Avatar
mojavepa
Cool question
i have a 99 150 with 5.4 with right around 124000 miles auto tranny my truck is vary slugy slow its pissing me off it dint start till a code got thrown witch was an o2 sensor but when i get on the gas the motor rev up to about 4 maybe 4.5 and accelarates vary slowly and doesnt start hauling *** till after it shift and this happens in any gear and at any speed.. yes ive "beat" my truck when i first got it and have hauled some stuff i should have but its really didnt start doing this till after i got back from a 2100 mile trip to mo with about a 1900 lb load can someone help
Old Apr 10, 2007 | 11:38 AM
ranger88a's Avatar
ranger88a
Shure the trans is sluggish and not the engine, I've had several engine power problems that affect the trans. Fuel filter is the major culprit, also the maf sensor.
Old Apr 10, 2007 | 01:42 PM
NevadaBlue's Avatar
NevadaBlue
Yeah you can change the filter and fluid in the trans and hopefully that will help...but....I have a feel'n you might be look'n at the torque converter ...thats where my money is at.....
Old Apr 10, 2007 | 09:34 PM
streethealer's Avatar
streethealer
If it revs up fine and just dosn't want to go, I'll agree with NevadaBlue. But if it is running like crap while under load, Ranger88a is probally right. I would definatly change the fuel filter, it's cheap and easy, $10/20min. Being a 1999 model, it has a drain plug on the torque converter. I would drop the pan, change the filter, drain the torque converter, and fill with 12-14qts of a good quality synthetic fluid. both are cheaper than a new torque converter and it may fix the problem or at least delay the enevitable. Good Luck!!!
Old Apr 10, 2007 | 10:34 PM
eveready77's Avatar
eveready77
I agree with changeing the fuel filter 100%. I also second the tranny fluid change. Some like it some don't but I like to have mine back flushed with all new fluid. If nothing else Try a bottle of "lucas transmission fix" It's darn near a miracle in a bottle for slipping transmissions. Can't hurt....that I know of anyway.
