300 to 351M?
Old Apr 10, 2007 | 12:29 AM
navyflyinggreg's Avatar
navyflyinggreg
300 to 351M?
I have a 85 F-350 w/ NP435. My carb'd 300 is toast and I am looking for a swap. I can't seem to find a 351W but found a 351M.
1) how do the 351M & 351W compare?
2) can I still use my NP435 (or whats a good replacement)?
3) I put a 3-core radiator when I rebuilt the 300 a few years ago - will I still need to swap that?
4) What ALL will I need to swap to make this work?
Thanks!
Old Apr 15, 2007 | 04:16 PM
Fmodster303's Avatar
Fmodster303
Thanks!
Dont got your anwer, but wondering the same for my 77 f250, so TTT.
Old Apr 15, 2007 | 06:24 PM
navyflyinggreg
I finally found a 351w short-block core that I am rebuilding
Old Apr 22, 2007 | 02:40 PM
Justjake71's Avatar
Justjake71
interested in this as well, if anyone knows something
Old Apr 23, 2007 | 09:10 AM
wizzard351's Avatar
wizzard351
need bellhousing to fit engine/trans flywheel for said engine mounts and frame stands.me personaly would never put am m into nothing but the scrap pile m = mistake but to each there own i gess. navyflyinggreg your 300 bellhousing will work and your flywheel will bolt up DO NOT use the fly wheel its balenced different than a v-8 and will vibrate your crank bad enuff to wipeout a new crank. i spose you could have everything balenced together at a good rebuilder tho
Old Apr 24, 2007 | 01:49 PM
Fmodster303
So to use the 351W all we need is the 351w flywheel and motor mounts.
Sounds good to me.
Navyflyinggreg update us on the install so we can copy you, lol.
Good luck, i have to wait till my truck doesn't need smogging and i'm getting the good ole 300 out!
Old Apr 25, 2007 | 05:09 PM
navyflyinggreg
Sorry guys...I found a Windsor last weekend so there won't be any 351M experiments for now. I am glad too...heard too much against using the modified.
The only question I have about the 351M, because of the larger deck height, does it produce more torque compared to the 351W?
Old Apr 26, 2007 | 05:18 AM
Fmodster303
Yeah windsor sounds great.
Old Apr 28, 2007 | 05:54 PM
Matts72's Avatar
Matts72
The real potential in the 351M is finding a 400 crank and pistons... HP/TQ are about the same for the 351M/351W, the heads on the M are way better than factory W heads, you can use the M heads on the Windsor block though and you will have a much better motor. The stock M heads flow better than performance GT-40 heads do for the 302/351W.
