boost question
Old Apr 9, 2007 | 09:13 PM
6.0superduty's Avatar
6.0superduty
boost question
I just bought an 04 superduty and I hooked up a boost and EGT gauge and the boost guage is only showing about 5-6psi of boost. I asked a couple of mybuddies about their trucks and they said it should be about 20-25psi. All the truck has is and Edge EZ towing module-60hp/100ftlb and a straight pipe. Any help is appreciated.
Old Apr 9, 2007 | 09:26 PM
adambomb's Avatar
adambomb
5-6psi is nothing! i would say that if the truck is driving fine and you have power and can hear the trubo maybe the boost gauges isn't hooked up right. i can see 25+psi and my truck is stock. good luck
Old Apr 9, 2007 | 10:02 PM
a-rod's Avatar
a-rod
Where did you tap your line in at? Max boost should be around 28 psi.
Old Apr 9, 2007 | 10:15 PM
Kep4's Avatar
Kep4
Jäger
It should be tapped into the intake elbow, just in front of the oil filter.
Old Apr 10, 2007 | 12:20 PM
F250tuff's Avatar
F250tuff
If you only have 5-6 lbs of boost, you would know it. It wouldn't have any power. If the truck has plenty of get up 'n go, it is a gauge or install issue.
Old Apr 11, 2007 | 09:10 PM
6.0superduty
The guage is "t"eed into the vacuum line that goes from the intake manifold to the MAP sensor. Im also not sure what the truck should be capable of. I just bought the truck about two weeks ago and it's my first diesel. The only thing I have to compare it o is a not stock mustang.
Old Apr 14, 2007 | 10:23 AM
6.0superduty
I called the local ford dealer and spoke witha diesel tech today. He said that the truck only make about 5-7psi when your just cruising around. He said that on the interstate, if you floor it, it might spike to 20psi. I was just wondering when you guys are raching over 20psi and is it different with a load than just cruising around?
Old Apr 14, 2007 | 11:24 AM
fomoconut's Avatar
fomoconut
I can nail the pedal from a dead stop and produce 20psi very quickly. Pulling up a hill I can make 30psi (pulling 4,500lbs trailer). My truck is completely stock and my turbo is 1 week old courtesy of Ford. I drilled and tapped (off of the truck) the intake elbow for my boost gauge.
Old Apr 14, 2007 | 11:52 AM
Bear Hunter's Avatar
Bear Hunter
Not sure how you are doing your readings...but you need to floor it and see what it is. A stock 6.0 will do around 25-27 (empty)....you'll probably see around 30-32 since you have a tuner.
Tapping into the MAP line like you did will cause the readings to flutter a little in the higher ranges (above 15psi generally). As mentioned above, tapping the intake elbow will eliminate the flutter at all ranges.
Old Apr 14, 2007 | 08:18 PM
6.0superduty
Thanks for all your help everybody. I will tap the intake elbow and if nothing changes, back the dealer. I hope its not a turbo problem because the turbo was just replaced 4,000 miles ago.
Old Apr 15, 2007 | 11:15 AM
fomoconut's Avatar
fomoconut
Are you sure its not a faulty guage?
Old Apr 17, 2007 | 07:38 PM
6.0superduty
I sure hope not, I just got it. I'll try another hand-held guage and compare readings. Thanks for the help everybody.
