1990 f-250 trans problem
Old Apr 9, 2007 | 08:15 PM
fordmancounty's Avatar
fordmancounty
I just bought this truck and it will not shift out of 1st gear if you put it in drive. But it will shift manually into second but not into high gear any help would be greatly appreciated so i can start driving it. I do know the fliud and filter need to be changed.
Old Apr 10, 2007 | 08:08 AM
adrianspeeder's Avatar
adrianspeeder
3speed automatic not shifting in D, but 1 and 2 manually work? Classic C6 problem, but it's an easy fix.
The C6's vacuum modulator on the passenger side of the tranny is a cheap replacement. Also, inspect the vacuum line that runs up to the engine manifold for leaks.
Adrianspeeder
Old Apr 22, 2007 | 09:46 PM
fordmancounty
Thank You Very Much For The Help It Was The Problem.
Old Apr 23, 2007 | 03:12 PM
adrianspeeder
Leak or new modulator?
Adrianspeeder
Old Apr 23, 2007 | 06:06 PM
fordmancounty
new modulator
