Math help desperately needed!
Old Apr 9, 2007 | 08:15 PM
Caplax40's Avatar
Caplax40
Oh FTE, I come to you in my hour of need. Here's is the problem:
"The profit function (in thousands of dollars) for a company is given by: P(s)=230+20s-(1/2)s^2, where S is the amount (in hundreds of dollars) spent on advertising. Verify the maximum profit algebraically. Use several sentences to help explain your final answer. In your discussion, use transformations to help explain your situation."
Any ideas???
Old Apr 9, 2007 | 08:31 PM
pchristman's Avatar
pchristman
s=20, p(s)= 430
Old Apr 9, 2007 | 08:32 PM
Caplax40's Avatar
Caplax40
How in the world did you figure that out?
Old Apr 9, 2007 | 08:53 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Doing homework are we???
Old Apr 9, 2007 | 08:55 PM
bf250's Avatar
bf250
please tell me your not in accounting or some other business major, if so i am going to switch.
Old Apr 9, 2007 | 08:59 PM
Caplax40's Avatar
Caplax40
Of course I am! And thanks to the power of the Internet, my homework is on its way to completion!!
Pchristman,
Thank you for your help!!! I don't know how you went finding an answer of 20 other than trial and error. Using those two numbers I was able to figure out what transformation model to use. It looks like I just need to wrap things up and be done!
Thanks again guys!
SpyFoxx's Avatar
SpyFoxx
Use a spreadsheet and calculate P for s= 0 to 100. Use the spreadsheet graphing function to see the curve. Print the graph and attach to your homework.
[edit] I did it real quick but can't paste the graph in here.
Old Apr 9, 2007 | 09:01 PM
andym's Avatar
andym
Use a spreadsheet and calculate P for s= 0 to 100. Use the spreadsheet to graph it and you can see the curve. Print the graph and attach to your homework.
So what happens if S=101? You can't pick a range when presented with a problem like this. You have to mathematically determine the answer.
The hard part is that you have to use algebra. If you are allowed to use calculus, it's a 30 second problem.
It's just a second degree equation, and you have to find the max of the function.
Old Apr 9, 2007 | 09:08 PM
Caplax40's Avatar
Caplax40
So should I work it as -(1/2)s^2+20s+230 and solve for S?
So I would have a problem that starts out similar to this:
-(1/2)s^2+20s+230
Like that?
Old Apr 9, 2007 | 09:16 PM
SpyFoxx's Avatar
SpyFoxx
Arrggghhhh, double post.
Old Apr 9, 2007 | 09:17 PM
SpyFoxx's Avatar
SpyFoxx
While I will agree with you, all he asked was how to find the maximum S. If 100 didn't give the top of the curve, it is a simples matter of copying down some more rows in a spreadsheet to increase S. So, I gave an alternative solution. Then in a few sentances he could have said since it is a 2nd degree equation, there would only be one maximum and it is . . .
And if you wanted, you could quickly give him a third way by using calculus.
He didn't say that he was limited to algebra (I think?).
Old Apr 9, 2007 | 09:25 PM
wrobo23's Avatar
wrobo23
my head hurts
Old Apr 9, 2007 | 09:32 PM
fordtrucklover94's Avatar
fordtrucklover94
Basically, take the derivative of the equation which would be P'(s)=20-s, set that equal to 0, there you solve s=20, take that and plug that back into the original equation, and you get P(s)=430.
I miss this stuff. Mechanical Engineer major math minor, here, finishing up my junior year, so i've seen this for a while.
Old Apr 9, 2007 | 09:42 PM
Caplax40's Avatar
Caplax40
Old Apr 9, 2007 | 11:07 PM
PEG's Avatar
PEG
Perhaps in simpler terms, P= -.5s^2 + 20s =230 is a quadratic.
The max profit will be at the vertex. Simply graph the equation (parabola) and find the value of P at that point. You can solve it algebraically by solving for the value of the vertex.
