I´ve an new problem on my 92" Bronco.
When I turn the steering wheel, a squiky noise comes from
my frond axle. I´ve greased up all ball joints, it´s not better.
Is it possible the power steering pump makes this noise?
I can´t exactly locate where it comes from. But I think it comes from the frontend
It could be your power steering pump but my wife's car made a similar noise and it turned out to the rack and pinion had gone bad. You could feel a dry spot in the steering as you turned the wheel and the front end squeeked as well. Hope you can figure it out :-)
