What are the odds?
Old Apr 9, 2007 | 03:35 PM
Olddog66's Avatar
Olddog66
What are the odds?
I had my truck in to get a rear hub seal replaced and the differential serviced. About three weeks later I noticed a leak on the drive and I looked at the differential cover...it looked like the cover was leaking. I took it back thinking they had screwed up the gasket on the cover but they called me an hour later and said the rear pinion seal was leaking now! I feel like I’m getting the shaft on this one no pun intended.
Old Apr 9, 2007 | 06:21 PM
jvoigt's Avatar
jvoigt
It sure sounds like someone most likely the mechanic might have fubared the seal or even damaged it while servicing you Diff or even just put the old one back in. Hope you get things straightened out.
Old Apr 9, 2007 | 06:30 PM
clux's Avatar
clux
I really don't see how they could have damaged the pinion seal servicing the differential unless they are completely incompetent. Is it possible that the oil level was down because of the hub leak, and filling the differential to the proper level made an already existing pinion leak more apparent?
Old Apr 9, 2007 | 06:34 PM
jvoigt's Avatar
jvoigt
Yeah oops I thought it was comeing out the diff cover seal.....but that sounds very possible. Well I hope thats the case and not shoddy maintenance.
