My 2004 Ford FX4 power window regulator on the drivers side needs to be replaced. Anyone have any idea how much that may cost in parts/labor at a dealership to have done? Thanks.
Go and buy the part from the dealer, should be about 120$. Its all one assembly.
Search this web site for the removal of your door pannel, its about 5 steps.
After you get the pannel off, there is 5 screws holding the hole unit in place.
Becarefull when removing them,make sure you hold the window up with something.I just wedged a small screwdriver in the bottom window molding.
Remove the old and put in the new. Its really not to hard to do.It took me about 1 hour.
