Charging problems
Old Apr 8, 2007 | 11:28 PM
launchrider's Avatar
launchrider
Charging problems
Hey so I have a 1992 F 150 and Ive had a problem lately that I havent been able to figure out. Last week I was driving home and my stereo cut out on me followed shortly by my signal lights and headlights spedometer exc. The engine didn't stop; but I only had to travel a short distance dont know if it would of or not. When I shut the engine off that night I tried to start it and it wouldn't. The next morning I got up and the truck started but very slowly due to a weak battery charge. On my way to work the battery charge went very low then rebounded back to the middle of the voltmeter on the dash. Followed by the battery charge going back down and the truck losing all power again. I have no idea what this is. The alternator is less then a year old, I also went around cleaned and tightened all the conections with a wire brush. Any Ideas would be greatly apprechiated
Old Apr 9, 2007 | 12:14 AM
SPL Tech's Avatar
SPL Tech
If your battery is dying well you are driving its something with the alternator. Maybe loose alternator cables or a damaged regulator. Regardless have the charging system looked at.
Old Apr 9, 2007 | 07:42 AM
subford's Avatar
subford
Sounds like you are losing the DC exciter voltage to the alternator (A/C Generator as Ford calls it). An alternator will only put out current for a short time after it is no longer excited. This voltage will slowly decrease until the engine dies.
Losing DC exciter voltage can be caused by a bad battery or a bad connection back to the battery. This could be the place where the batteries Negative cable attaches to the block, either battery post, at the connection on the starter relay or at the alternator itself. Also bad battery cables can do this.
I think your alternator is still good and you have some wires or a battery to look at. About the only thing that can come an go in an alternator is the brushes and unless it was a poor rebuild job on it the brushes should last longer than a year.
Old Apr 16, 2007 | 08:07 PM
Planspec.1's Avatar
Planspec.1
If you can get the truck to run disconnect the battery cable. If the truck stalls out it's your alt
Old Apr 16, 2007 | 08:40 PM
Franklin2's Avatar
Franklin2
This is not a recommended procedure for a newer vehicle with electronic ignition, computers, and expensive stereos. You can get a voltage spike through the truck when you do this, and burn out lots of stuff. I have done it before and burned out the ignition module.
garydmundy
Nov 25, 2013 09:45 AM
Tim98TA
Electrical Systems/Wiring
Sep 11, 2013 06:29 AM
ITDave
2004 - 2008 F150
16
May 11, 2009 10:52 AM
rob-o
Jan 29, 2009 08:32 PM
01FordCrew
Mar 19, 2008 05:26 AM
