Drive Shaft
Old Apr 8, 2007 | 10:24 PM
tonpartain's Avatar
tonpartain
Drive Shaft
What is the blue coating on the splines of the drive shaft? I was told by a fella that rebuilds drive shafts that I cannot have mine powder coated because it would cause the blue coating to melt off. Anyone ever heard this?
Chris
Old Apr 9, 2007 | 07:23 PM
Redcat Diesel's Avatar
Redcat Diesel
The blue coating is a plastic material that is designed to minimize spline wear and galling ( siezure) from lousy maintenance.The coating is thick enough that if removed will result in noticable play in the slip joint.Sorry I can't help with the powder coating question.Hope this helps.
