Engine Size?
Old Apr 8, 2007 | 09:02 PM
jeff2761's Avatar
jeff2761
Engine Size?
My nephew pulled home a truck today. The title says '75 but it has a '78 or '79 grill. I believe someone has probably taken two trucks and made one. It's got 4wd and is a standard shift. What is the best way of determining the engine size? He needs to change the clutch out but he's unsure of the size. It's definitely a v8 but unsure of the cubic inches. Thanks.
Old Apr 8, 2007 | 09:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975
302 = 6 valve cover bolts
360/390 = 5 valve cover bolts
1977/79
351M/400 = 8 valve cover bolts.
460 engine were all C6 automatics: 1973/79
Old Apr 8, 2007 | 09:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
-There are other indicators but these are enough to distinguish engine families.
Looking at the block at the base of the distributor the 351C will be even with the bottom of the intake manifold. With a 351M/400 there will be a ~1" high lip up to the bottom of the intake manifold.
Old Apr 8, 2007 | 09:59 PM
Mil1ion's Avatar
Mil1ion
Nothing to add here
Old Apr 9, 2007 | 04:18 AM
Alvin in AZ's Avatar
Alvin in AZ
That sucks. :/
Alvin in AZ
Old Apr 9, 2007 | 05:58 PM
jeff2761's Avatar
jeff2761
Thanks to all for the info. He's changing the clutch as we speak.
Old Apr 9, 2007 | 09:43 PM
Alvin in AZ
Originally Posted by Mil1ion
Nothing to add here :(
LOL :)
You're just going to have to be on the ball with Eric and Bill around. :)
Alvin in AZ
Old Apr 9, 2007 | 10:10 PM
79-400-POWER's Avatar
79-400-POWER
Nothing to add here
then what you post fur
Old Apr 9, 2007 | 10:15 PM
Mil1ion's Avatar
Mil1ion
For laughs...Alvin hit on why .....Did you not laugh ?
I don't know how many times I have answered a post and 10 people after me posted exactly the same thing.
It's called redundancy ...
Old Apr 10, 2007 | 03:55 PM
Alvin in AZ
Sometimes different wording makes a big difference when something totally new is trying to be understood. And it's not like redundancy uses up paper or something. ;)
Alvin in AZ
Tofan
2009 - 2014 F150
Feb 10, 2014 12:37 PM
westkane
Jul 1, 2013 05:10 PM
Kris23
Jul 1, 2012 10:37 AM
1979fordf150rebel
Jan 25, 2012 11:03 AM
mikedeason
Apr 2, 2007 10:38 AM
