shudder bug won't run
Old Apr 8, 2007 | 07:52 PM
95Ford4x4's Avatar
95Ford4x4
i've got two problems, 95 f150 300-6. first off, i have an aod tranny in it that when in overdrive is has a shuddering vibration, but when i drive it in DRIVE it runs fine. is this the tc chatter others have talked about?? if so, how can i go about fixing it. the second is, after sitting overnight i have to spray starting fluid into the intake to get it cranked up. before anyone asks, my truck was a stick and i converted to automatic and went with aod to avoid the electrical issues. thanks for any help.
Old Apr 8, 2007 | 08:18 PM
Dukernc's Avatar
Dukernc
I had the same shudder problem and thought it was the AOD. My truck started to develop a bad shudder on the highway while going up any hills especially when in over drive, whether empty or with a load in the bed. I'd also down shift into drive and it would go away. I stared to do all of the obvious transmission things.. checked the TV cable adjustment and pressures..etc.. and found nothing wrong. Then one day while sitting at a traffic light I noticed a slight skip in the engine and decided what the heck I might as well take a look at it? Plugs didn't look to bad, wires seemed to ohm out ok, cap and rotor (aluminum) were badly pitted. So, I decided to do a complete tune-up... autolite plugs, wires and bronze tipped (not aluminum) cap & rotor. Well the shudder was completely gone! I'd also consider changing the air filter & the fuel filter especially if you don't know when they were changed last..Just my $.02 I realize that you have a 6 but, hey it's worth checking.. Good Luck!!
Regards,
Dukernc
1999 F-350 CC Lariat Dually LB 7.3L, 6 speed, 4.10, Linex bed liner, 4" Magnaflow SST turboback exhaust w/ 5" tip
1990 F-150 XLT Lariat 4X4 SB 5.0 EFI, 3.55LS, Modified AOD w/auxiliary cooler, cat back, all around farm truck
Old Apr 8, 2007 | 08:39 PM
95Ford4x4's Avatar
95Ford4x4
i've replaced the cap,rotor, plugs and wires, also have new fuel filter and front tank pump is new. i do have some old gas that might be part of the problem, then shudder i hope will go away as i run the old gas out, but the starting fluid to first crank it up in the morning worries me.
Old Apr 8, 2007 | 08:41 PM
95Ford4x4's Avatar
95Ford4x4
i also just put a can of seafoam in the gas tank and a can down the intake, so hopefully that will help things out too.
