Oh, and does anyone know the correct "wet" float adjustment for the '78 400 engine? Mine is classed as "heavy duty" on the valve cover decal if this makes any difference.
1. Choke pull-off leaking bad. Real bad. Would not even attempt to hold vacuum.
2. Air cleaner duct motor leaking
Only other "leak" I could find was that the Vacuum Amplifier leaks vacuum when vacuum is applied to the port going to the EGR valve. The vacuum leaks from an unused port on the amplifier. Is this a vent? That's my guess.
I still have a slight hesitation that occurs a second after I accelerate during cruise. I think it is the EGR kicking in....but I guess this is normal.
If anyone can tell me if the amplifier leak is normal I would appreciate it. Thanks for all of your help.
