RAP Module Pinouts
I'm installing a remote starter into my '00 Navigator and would like its unlock/lock function to mimick the factory behaviors. I've found taps for the parking lights and the horn to make them work like factory, however I have not found a place to tap to activate BOTH the dome lights and running board lights. I figure since the factory system does this, the RAP module must have an output that goes to these systems. However, I do not have a wiring diagram to figure out which wire's which, I only know the lock/unlock pins. Does anyone know which wire at the RAP module connects to the dome/running board lights? Or have a schematic/diagram for the RAP module itself? Any help would be greatly appriciated. Thanks!
You can probably find the information you need at a specialty forum such as www.the12volt.com that deals with automotive aftermarket devices and installs.
Steve
