ok when i put my truck in gear my d-shaft spends backwards then goes forward real quick and makes a dingin noise ... my u-joints r not bad they have already been checked ... wats causin this ? im sick of hearin it ... thanks Bigun
Just get in there and find out where the play is and deal with it. Worn U-Joints can cause a ding but more often it is excessive play in the differential pinion.
so are you sayin just drop the d-shaft down and put a hand full of grease like inside and on the yolk ? or take the yolk off and put it in there and then put the yolk back on ...
remember im 16 so it takes me a minute to get it all in my head
the grease is just taking the noise away it is not fixing the problem i had the same problem in my 79 and when i repleaced the gears in the rear end it fixed the problem so you might look into that to make sure your rear end is not going out
