Dealer Diagnostics
Old Apr 8, 2007 | 12:59 PM
jboard's Avatar
jboard
Question Dealer Diagnostics
I am goin to be taking my truck to NC in the fall for school im in WV would it be a good idea to take my truck to the dealership for a full computer diagnosis to check everything out befor i go? Does that check the transmission and injectors too? as well as the engine? What other things does it check?
-------------Jeremy
Old Apr 8, 2007 | 03:29 PM
bkcowboss's Avatar
bkcowboss
I wouldn't ..... my $.02 Listen carefully to how she runs. All I do is check and change the required filters and fluids, and keep an eye on the forum so that I recognize issues early. The stealer ship is just gonna charge money to tell you what you can deduce yourself most of the time.
Old Apr 8, 2007 | 05:35 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I agree with bkcowboss. Unless you are having problems, it is not money well spent. You can usually tell when something is not right, injector not firing, running ruff, transmission shifting hard or late, etc. So unless you have a problem, save the money for fuel.
Old Apr 8, 2007 | 07:44 PM
powerstroked162's Avatar
powerstroked162
I supprot that info supplied to ya by BKcowboss and Plowhand
Cowboy Steve
Old Apr 8, 2007 | 09:40 PM
jboard's Avatar
jboard
Well my tranny is kinda doin something weird I can hear a pretty good thud when goin from D to R or R to D which is new and It kinda vibrates when thers a load against it before it shifts down and it feels like its in the tranny and id like to kno if theres something wrong. It also has this weird clunk when i let off the pedal and get back on it feels and sounds like it comes from the TC. I also get a od flashing light and CEL often and funky shifting.
---------jeremy
Old Apr 8, 2007 | 09:59 PM
RubberDuck's Avatar
RubberDuck
---------jeremy
Jermy, you may not want to hear this but here goes. Best case senario is your U-joints are shot. i.e. causing the vibration and banging going from D to R. That's my first thought. But when you talk about the flashing OD light, that tells me VSS on the rear diff. My only thought there is that I hope the gears aren't eating themselves and all the metal shavings are screwing up the VSS reading. I would say check all your Driveshaft U-joints and clean or replace the Vehicle Speed Sensor on top of the rear diff. Good luck man, I hope that helps. I'll be pullin' for the U-joint's VSS to be the problem.
Old Apr 8, 2007 | 10:01 PM
RubberDuck's Avatar
RubberDuck
One more thing, if the truck vibrates badly under a load, you might also check to see if you are getting axle wrap. Meaning, the rear axle is turning up twards the bed. That will also cause huge vibrations.
Old Apr 8, 2007 | 10:11 PM
big inch's Avatar
big inch
---------jeremy
That would definitely warrant a trip to the dealership, especially before you go on a trip.
Old Apr 8, 2007 | 10:33 PM
IDMooseMan's Avatar
IDMooseMan
I'm with RubberDuck on this one.
Old Apr 8, 2007 | 10:36 PM
jboard's Avatar
jboard
Yea thats why i asked. the vibration aint real bad but i notice it. and the u joints are good ill check rear end. and I will replace the VSS and see if this helps. the OD light flashes and the CEl usually comes on as soon as i turn the key then go off after bout 3 min or so. but the shifting is still funny untill i shut her down and restart.
---------jeremy
Old Apr 8, 2007 | 10:41 PM
IDMooseMan's Avatar
IDMooseMan
I forgot that you mentioned the OD light flashing and the CEL. That might be caused by a bad CPS. I had a similar situation where the OD light flashed, the speedometer went nuts, the odometer went blank, and the engine stalled and restarted on several separate occassions.
I replaced the CPS and the VSS. She smoothed out after that.
Old Apr 8, 2007 | 11:07 PM
RubberDuck's Avatar
RubberDuck
Good call Moose!
Old Apr 9, 2007 | 06:18 AM
Cuda_jim's Avatar
Cuda_jim
---------jeremy
Take alook at this thread:
https://www.ford-trucks.com/forums/5...rivetrain.html
The center bearing may be causing the vibration. It probably doesn't have anything to do with the CEL tho, IMO. Moose and Duck got ya covered on that one.
Old Apr 9, 2007 | 03:21 PM
jboard's Avatar
jboard
Well I changed both the U joints today along with the speed sensor and no more clunk which is great and drove it about 30 miles to pittsburgh and 30 miles back and got no CEL and feels like a new truck. I also got an ICP off ebay with i hope will fix the wondering idle. So right now im good to go. BTW our local ford dealership charges 100 dollars for a diag which they say is very thorough. Im good for now but if anything weird happens again then im taking it there.
---------------Thanks for all your help, jeremy
Old Apr 9, 2007 | 05:08 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Glad you got it fixed.
