I JUST GOT A 73 F100 A YEAR GO TO RESTORE AND PUT A 78 VAN MOTOR IN IT AND RUNING GOOD BUT ONE PROBLEM IS THAT THE GAUGE IS FLICKERING AND SO IS THE LIGHT IT VOLTAGE REGULATOR AND BATTERIE AND ALTERNATOR ARE NEW
Welcome to FTE; I'm sure others are more technicial than I and will chime in soon; but to determine your initial possible problem; I recommend checking all your ground's and to include all dash contact's; too ensure a good contact point. Hope this helps...
Welcome to FTE! If it is Ford info you are looking for this is the place to be. I am no expert on electrical, but there are others on this site who pretty much know everything there is to know about Ford trucks. (Mil1ion, and Numberdummy to name just two)
2nd: Please please in Lower case and in the FTE default font
"""""No code""""
It makes for Easier reading.
3rd) Please p[ut thr actual topic of the thread in the title.
Ie: Faulty Instrument Gauges
4th) Topic:
I presume you mean the gauge needles are acting like a fast windshield wiper?
The Ford Gauge monitering system works on a 'Pulsed power signal to a ground out.'
If grounds are bad you will get inaccurate reading.
If the pulsing power is bad you will get an inaccurate reading.
IMO that you remove the cluster and clean the Printed circuit board and the Instrument cluster Voltage regulator mount and power connection.
Follow the blue arrow to see the ICVR:
But First !
NOTE:
also test the ICVR for a pulsing power at any Sending unit connecting wire before you take the cluster out.
You should see a steady Pulse of 5 volts
Thank You I'am Going To Check That Out My Niece Just Ask To Check Out Her Ford Windstar The Power Wondows Are Not Working I Here Is A Click Noise
It Is A 2001
i actually have the same year truck and have had the same problem, and i tell u what its a pain in my rectal area....but, what i would do first is, check to see if u have any dust on the circuit board if so, get a can of air and spray it clean. then i would take the circuit board off the cluster and check for any breaks in the ciurcuits. i had some breaks in mine and it did the same thing u described. I know from experiance dealing with these things how crappy it really is to have to figure out the issue. let me know if any of this works. if not i have some more steps you can take.
I already clean the circuit board but i did't check for breaks but i use a circuit boards out two othen trucks they did the same thing the truck are in a junkyard it more like they wear bad two
well if that wasn't the issue what you wanna do next is check the fuses under the dash, there are some itty bitty fuses under there that are hard to determine if there blown bec. there so small...i woul take one out and replace it and see if that fixes the issue before you go buyin a new cluster.
thank you, I already replace all the fuses this is the first truck i ever seen like this
someone toll me it the wireharness from the alt to voltage regulator is bad so if you think of any thing i wood like more info. thank
