96 ranger 2.3 Idle problem SOLVED!!!!!!!!
Old Apr 7, 2007 | 10:04 PM
chefrobert's Avatar
chefrobert
After replacing the head and head gasket , the engine had a rough idle. Tried everything-Next step was to change out fuel injectors. As I was cleaning the EGR I had to move the vacumn line out of the way and heard a cracking noise. Voila!
The Egr Vacumn line originates on the Driver side of engine of of throttle body and crosses over valve cove and rides down to the right front of engine where it goes through some sensor, It then makes it way back to the EGR valve. ANYWAY It and 2 other vacumn lines all made of the thin plastic all are encases in the same protective black plastic slip cover. These 3 lines were brittle as could be and were leaking. I could hear no hissing as the 3 are inside the pastic guide. I replaced all 3 with new plastic and rubber vacumn lines and all is good. Idle is real smooth. I never read this before so I am adding. I am one happy individual!
LOOK AT YOUR HIDDEN PLASTIC VACUMN TUBING-It becomes brittle after 10+ years!!!!!!
Old Apr 7, 2007 | 11:38 PM
john112deere's Avatar
john112deere
Hmmm.... might have to take a look at mine next time I'm under there.
Glad to hear you got it fixed.
Old Apr 8, 2007 | 08:58 AM
crazypaw's Avatar
crazypaw
Wink
hi chefrobert,
CONGRATULATIONS! Ocassionally we all get as lucky as you have and at that time REJOYCE!!
Old Apr 8, 2007 | 10:14 AM
fflintstone's Avatar
fflintstone
Good post Chef!!!! It's always good to get posts of successfull troubleshooting/diagnosis. It'll be one more resource when someone does a thread search which is the first line of attack for someone looking for solutions to their truck problems which is what this forum is all about.
Glad to have ya
Fred
Old Apr 9, 2007 | 07:40 AM
customstringer's Avatar
customstringer
I would be interested in what parts you used for this replacement and where you got them. Also any particular things to watch for during the repair.
1982Boss
Jan 30, 2017 07:37 PM
1982Boss
Jan 29, 2017 08:04 AM
g tinsley
Mar 19, 2015 06:28 PM
90fordf-250
Nov 20, 2011 08:51 AM
CVokie
22
Jul 31, 2005 12:13 AM
