Trans. Fluid Additive?
Old Apr 7, 2007 | 09:04 PM
tommyl's Avatar
tommyl
My old transmission is wanting to run a little hotter than normal, I think. Is there an additive that I can add, or can I just drain the oil that is in the pan and refill whith synthetic fluid? Or should I go all the way and have a tran shop drain and refill the entire system? '99 PSD, automatic, 792,000 mi.
Old Apr 8, 2007 | 07:08 AM
Cuda_jim's Avatar
Cuda_jim
792K miles, Holy crap! You might hold the record for the most miles on this site??
Do you have a trans temp gage? IF so, what is the temp?
Is it shifting OK?
Usually just changing the fluid won't reduce your temps IMO, even switching to SYN won't lower the temps, but SYN ATF can take the heat better than dino oil. A trans shop won't get any more oil out of it than you will. Drain the converter and flush out the cooler(s) will get just about all of oil out of it.
Old Apr 8, 2007 | 07:21 AM
DieselCamper01's Avatar
DieselCamper01
I don't mean o hijack this but how do you drain the converter? Is this a remove the trans type job?
Old Apr 8, 2007 | 07:25 AM
Uzumati's Avatar
Uzumati
Na older trucks have a drain plug in the TC under the inspection plate. But you dont have to manually drain it the pump will flush it for you
http://www.7point3.com/Writeups/TransFlush.aspx
Old Apr 8, 2007 | 07:38 AM
DieselCamper01
amiller. Thanks for the great link. I will be doing this soon. Bought my 2001 in January
with only 34,000 on it but want to change all the fluids since I do not know how
often anything was done.
Old Apr 8, 2007 | 08:07 PM
tommyl's Avatar
tommyl
My thanks too for the info!!!!
Old Apr 8, 2007 | 08:14 PM
F350-6's Avatar
F350-6
I can't speak for everyone else, but if you've gotten 792,000 miles out of your transmission and engine, I'd say do whatever you think is best. You've obviously done pretty well so far. I'm sitting in the low 200's so I would follow your advice.
bakos
Jan 27, 2013 02:58 PM
visco
1997 - 2003 F150
Jun 11, 2011 03:51 PM
conti98
1983 - 2012 Ranger & B-Series
Oct 11, 2004 06:09 PM
Schmavic
Apr 14, 2004 01:29 PM
Airplanes31098
May 5, 2003 07:21 AM
