Sponsored by: Kumho
Rear ABS Bleeding question
Old Apr 7, 2007 | 06:07 PM
Nadenal's Avatar
Nadenal
I have a 96 Aerostar 4wd w/ rear abs. I need to do a rear brake job and rebuild the wheel cyl. My question is this. Will I need to bleed the entire abs sytem using all of the special tools, or can I just get away with bleeding the two rear lines like normal?
Thanks in advance.
Mike Weber.
Old Apr 8, 2007 | 11:23 AM
cujo8's Avatar
cujo8
You will only need to bleed the rear lines. The front and rear brake systems are separate, so no air should get into the front brake system.
