looking for a stronger set of motor mounts for my 78 f350 2wd running built 460
any ideas or should i jusst chain it if so how
i have broke stock mounts and l&l mounts
Solid mounts are not a good idea unless you have a dragstrip only truck.The vibration would likely rattle your teeth.Also if you are in an accident, even a minor one and the frame flexes there is a good chance of breaking the side of the block.If mount breakage is an ongoing problem you might want to consider some sort of restraint cable instead of a chain.A cable has some elasticity to it whereas a chain can snap under a sudden shock load.Chevy had a big problem with motor mounts in the '60s and they retrofitted a cable setup from the manifolds to the upper control arm brackets.Hope this helps.
solid is the way to go. I've seen the L&L motor mounts and if your breaking them somethings wrong.I make my own and had they never broke and rattled my teet,but a chain sounds good if you can keep the plaay short.
The FE blocks have been famous for years for breaking motor mounts, especially the left. The 460's do not have that bad reputation. Solid steel motor mounts were once the only thing available, but in 1932, Plymouth became the first car to offer rubber mounts. Plymouth called it "Floating Power." The idea was simple then and it is simple now. Solid steel motor mounts will radiate every bump, jolt and nuance inside to the cabin. How long will some of the powertrain parts, designed for rubber mounts, hold up under the solid system?
Something to consider, before making changes that may cost you dearly down the road.
Motor oil is the enemy of rubber mounts. The mounts can soften and eventually fail. The 1973/79 F Series 460 mounts are the most dependable that Ford ever made...then or now, because of the mounting system and having the upper brackets (6030/6031) enclose the mounts.
my stock mounts were old worn and may have been install worng by the orignal owner thay were more so really badly worn than broke the l&ls were bouth torn in half sorry about the spelling
so motor oil can cause the mounts to fail? that would have to be a lot of oil soaking to cause that kind of failur? Idid not have an oil leak that would cause it
I have ripped out 2 L&L mounts both times the rubber was still cold in the winter after about 5-10 min of driving and getting on it. I don't seem to have a problem if the rubber has been warm from the summer temps or engine heat in the winter. The L&L's don't seem to hold up any better than the crappy stock FE mounts IMHO.
A Chain or limiting strap would get the job done. I have a Stiffy Engine Torque Damper that I haven't installed yet that my GF bought me for my birthday last yr.
