Factory gears
Old Apr 6, 2007 | 08:08 PM
flareside_thunder's Avatar
flareside_thunder
Factory gears
I have a 1995 F-150 Flareside with a 5.0 and AODE and an 8.8 rear with a posi....any ideas on the stock gear ration for this truck?I changed my fluid in it when I got the truck and removed the tag....no idea where it's at....any other casting numbers other than on the ring and pinion set?
Old Apr 6, 2007 | 11:59 PM
Dustin1690's Avatar
Dustin1690
Open the drivers side door and look on the door jamb and look at the vin check axle code there and come to articles and got to vin decoder and look for the axle code and it should tell you your ratio
Old Apr 7, 2007 | 09:01 AM
flareside_thunder
Thanks a million Dustin...learn something new everyday.
Old Apr 7, 2007 | 11:21 AM
Conanski's Avatar
Conanski
You could also put a piece of tape or chalk mark on the driveshaft and count the number of revolutions for every wheel revolution. There were only so many combinations used, and 3:08, 3.55, 3.73 and 4.10 are the most common.
