How Long a Life?
Old Apr 6, 2007 | 11:50 AM
DocMerdoc's Avatar
DocMerdoc
Question How Long a Life?
Alright, I am looking at purchasing a 1978 F150 with a 351M which has approx. 13x,xxx miles (according to the seller). What is the average life expectancy of this type engine? And what can I do to prolong it's useful life? Hoping the owner has cared for it well enough, I know I would.
Old Apr 6, 2007 | 12:21 PM
monsterbaby's Avatar
monsterbaby
Welcome to FTE
As to average life, I don't think there is a set answer for that, it all depends on how it was cared for and used or abused. I have seen 351M/400 with well over 200,000 on them still running pretty strong and seen others with less than 75k that needed work.
I would run a compression test, and put a mechanical oil gauge on it and see what the pressures are first off to get an idea of the condition of the engine, also run it with a vac gauge and make sure it's pulling good steady vacuum this will give an indication of condition also.
As to extending it's life, well assuming it's in good condition now, just the basic maintenance, keep the oil changed, change the antifreeze and all other fluids (I do this with any used vehicle I buy) I also run some carb cleaner in the fuel and then change the fuel filter etc.
Old Apr 6, 2007 | 12:57 PM
Redneck91's Avatar
Redneck91
The 351m are known for the oil returns getting plugged, I would take the valve covers off, and look at the heads. I have seen many run for 200K plus it just depends on how the engine was taken care of. Check Oil Pressure and Vac. Usually when I get something like that from someone, I will go through, and change timing set, Oil pump, and all fluids.
Old Apr 6, 2007 | 01:48 PM
firstonraceday's Avatar
firstonraceday
As you can see from my sig, the 351M in my 77 made 315,000 miles before rebuild. Oil pressure was plenty low prior to the rebuild, still ran strong though.
Changing the timing set is a good idea if it has not been changed. The factory set consisted of nylon gears which did not lead to a long life. I changed to a double roller set about 30,000 miles prior to rebuild.
Old Apr 6, 2007 | 02:28 PM
53fatfndr's Avatar
53fatfndr
The 400 in my '79 has right around 190,000 miles on it. I need to get another 2-years (10-15k) out of it before I can afford a rebuild. The valve guides have been going out for the last 50k as it smokes on start up. I'm going to replace the timing chain and water pump this summer. It still runs good, but it is closing in on rebuild time.
Old Apr 6, 2007 | 05:15 PM
DocMerdoc's Avatar
DocMerdoc
Thanks to all. I figured that if you care for your Ford, it cares for you. The guy also said that he replaced the oil pump. If I decide to purchase, I will definetly check all the suggestions you speak of.
Old Apr 6, 2007 | 06:11 PM
havi's Avatar
havi
I'll have the Roast Duck
my experience has been the rear main seal. Maybe it's an "up-north" thing, freeze, thaw, freeze, thaw, etc...
Old Apr 6, 2007 | 07:36 PM
DocMerdoc's Avatar
DocMerdoc
havi, thanks for the reply. That issue you mention supposedly has be addressed by the current owner and has been replaced. Every little thought and idea helps me.
Old Apr 6, 2007 | 09:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Those nylon timing gears can fail anytime after about 80K miles.
