Sponsored by: Auxito
A/C Compressor noise.
Old Apr 6, 2007 | 11:34 AM
150mudder's Avatar
150mudder
Question A/C Compressor noise.
I have a 2002 f150 5.4L. i was out off-roading one night and when i started my truck up the next morning the ac compressor was extremely noisy. Sounds like mud got into the bearings or water got in there and washed the grease outta there. i was wondering if anyone has had this problem before. or what would be a simple fix short of getting a new complressor. and the reason i know its the a/c is because the tone changes when the compressor engages and disengages.ANY HELP WOULD BE MUCH APPRECIATED.
Bryan.
Old Apr 7, 2007 | 12:30 AM
86moneypit's Avatar
86moneypit
I had a problem with my compressor making noise the dealer was able to replace the clutch and pully and it fixed the noise
Old Apr 7, 2007 | 10:45 PM
150mudder's Avatar
150mudder
thats what i thought i had to replace, thanks for the input back though.
Old May 8, 2007 | 05:40 PM
astamp78's Avatar
astamp78
A friend of mine just bought an '02 F150 with 108k miles. He decided to drive around in the flooded streets recently for fun, now the AC compressor makes noise all the time. It is not a squeal, more of a light grind / harsh rub sound. The AC clutch works fine, it just sounds like maybe dirt in the bearing?
Is it possible to lubricate?
Old May 8, 2007 | 06:49 PM
Beast12's Avatar
Beast12
I would get that looked at ASAP. My Dad had the same noise with his truck and he left it for about a month. Ended up seizing up and made it so he couldn't drive his truck. Cost about $500-600 to fix it including a new belt.
-Matt
Old May 8, 2007 | 09:42 PM
daddyd5150's Avatar
daddyd5150
At a minimum you should take the clutch off and clean it out and inspect it. I would replace it and not chance it though.
Old May 9, 2007 | 07:22 AM
150mudder's Avatar
150mudder
astamp, that is exactly what mine sounds like. noise came after i was out wheelin. i believe water got in there and un-lubricated the bearings or something like that. trying to save the money for a new clutch and stuff.
thanks for the input everyone.
Old May 9, 2007 | 07:55 AM
astamp78's Avatar
astamp78
Are there any special tools required, I have never messed with an AC compressor before.
Thanks,
Old May 9, 2007 | 08:57 AM
daddyd5150's Avatar
daddyd5150
Thanks,
It makes it alot easier if you have a clutch removal tool. Ask your local NAPA which tool you need.
