Sponsored by: Auxito
Need bolt hole
Old Apr 6, 2007 | 09:51 AM
star's Avatar
star
Need bolt hole
Could some plese tell me the 5 hole "bolt pattern" for a 2000 F150 ? thanks !!!!!!!!!
Old Apr 6, 2007 | 11:19 AM
KingRanchMan02's Avatar
KingRanchMan02
You have a 5 hole, 135mm bolt circle pattern. Early models use a 12mm stud. Later models use a 14mm stud. I am not sure when the switch to the 14mm studs took place. I do know that my truck has the 14mm studs. Good luck!
Old Apr 6, 2007 | 05:01 PM
wgotthardt's Avatar
wgotthardt
As John said..5X135mm
The model year 2000 was the split year in which Ford switched from 12mm to 14mm lug studs. If a 3/4" socket fits on your lug nuts, you have the 12mm, if not then you have the 14mm.
Megadiesel08
Dec 3, 2012 07:20 AM
PolishMike0525
Mar 26, 2010 12:59 PM
Nedcampion
Mar 27, 2007 04:49 PM
Fordlvr74
Garage & Workshop
22
Aug 26, 2005 12:00 PM
skeleton33
Flathead V8 & Flathead 6
Apr 28, 2004 01:08 PM
