94 e-150 front shock removal...help
Old Apr 5, 2007 | 02:26 PM
peckhamjusten's Avatar
peckhamjusten
i got the top part of the shock off but kant seem to get the bottom stud off. i had to cut the bolt off. is the stud pressed in or is it screwed into the frame? thanks
Old Apr 5, 2007 | 10:28 PM
maples01's Avatar
maples01
It's welded to the radius arm, you can see the round indention on the outside of the arm where it's at, I suggest using a drill dead center and drill from the outside in, then install a bolt through the radius arm and shock, makes for easier repairs. I broke the nut off of a friends, his shock is resting on the remaining bolt, won't come off without removal of the top, didn't have time to replace it. I was going to drill it out as I described above, but he's been fine with it, hasn't stopped driving it long enough for me to repair it.
