block Idenification
Old Apr 5, 2007 | 10:58 AM
josh85's Avatar
josh85
block Idenification
I bought this short block off ebaymotors about 6 months ago. It was supposed to be a 360, but it is a 79 which does not make sense since 360 were not made in 79. Also the block has to small freeze plugs where the camshaft retainer bolt holes are supposed to be. The crankshaft is a 2TA which is a 360 but I dont feel safe putting a camshaft in it with out a camshaft retainer plate on. The castings on the block are 79U EDC 6015c I've called every junk yard in the phone book and no answers. I think the 79U is econoline but don't know anything about them. Thinking this was a 360 on its way I also bought a 390 crankshaft for it to stroke it out, but not knowing the duration or the cam retainer mystery I don't want to touch it until I know exactly what I got. If anybody has any insight on this it would be greatly appreciated
Thanks
Old Apr 5, 2007 | 06:17 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
You aren the 09 forum see what you can find out in the engine forum??
Old Apr 6, 2007 | 06:49 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Are you certain the block is a 79? That sure sounds like a early block. The EDC-6015-C casting is a 60 HP block for the 390 hipo. It could have a 59 date code for a 60 block as that's pretty common. What's the 79U and where is it on the block. Is there a date code on the side of the block above the oil filter adapter? Early blocks also used 2 bolt motor mounts vs the later 4 bolt bosses. That's another clue to look for. I don't recall Ford bringing back the EDC reference on later blocks but you never know? Being an early block would also maybe explain the plugs where the retainer goes. Those used a stamped steel timing cover... with a thrust button spring thingy glued on the inside .You can tap the holes and use a later cam retainer plate. Let me know what you find....
G.
Old Apr 6, 2007 | 05:19 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I should clarify the above as I can't now edit it for some reason...when I said 60, 59 etc... I mean a 1960 or 1959 block casting or date code etc... Just to clear that.
G.
Old Apr 6, 2007 | 07:30 PM
josh85's Avatar
josh85
block Identification
Thanks alot for the knowledge. I looked at the block there is only two bolt holes for the motor mounts, and the 79u is directly above the casting numbers. I looked above the oil filter adapter and did not see any numbers. there is a symbol below the oil filter adapter that looks like a C with an F in the middle of it and right next to it a 1 3 5 7 in a protruded in a circle don't know if that means anything.
Old Apr 6, 2007 | 08:59 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I'm sorry I'm wrong on the block ID. It's a 352HP block not a 390 HP. It's still a hipo block but came stock with a 4.00 bore. The 390 was a 4.05. My error on that sorry. The 390HP was a 61-62.5 then the 406 from 62.5 to 63.5 when the 427 came out. Still a great block and nice piece of Ford history. The CF is for the Cleveland foundry where the block was cast. The circle with the numbers is the casting clock. Those were used to either tell when during the month that batch of blocks was cast. Or what time and shift of the day the block was cast. Sorry on the mix-up....
G.
Old Apr 7, 2007 | 08:01 PM
josh85's Avatar
josh85
Thanks alot for your time. I was wondering what a Hipo block was I've been looking on the internet and not getting that much information. Also can you interchange the crankshafts like with the FE 352,360 and 390. After reading the bore specs you gave me I went out and measured the bore at 4.080 with 30 over pistons in it that would give me a 4.050 before the bore. I went out with a magnifying glass still trying to find soming that could be a date code still no luck.
Old Apr 7, 2007 | 08:19 PM
428HIGHBOY's Avatar
428HIGHBOY
it sounds like it is a 390 block. the 390 was a standard bore of 4.05 so 30 over would be 4.08
Old Apr 7, 2007 | 08:26 PM
Bear 45/70's Avatar
Bear 45/70
A lot of the Hipo block had really thick cylinder walls. I was able to punch a 1962 390 Hipo block to 4.13 to make a 428.
Old Apr 7, 2007 | 08:49 PM
josh85's Avatar
josh85
A 428 how much horse power do you get out of it, and what is it in.
Old Apr 7, 2007 | 08:56 PM
428HIGHBOY's Avatar
428HIGHBOY
If you are refering to me, I am regulated by d_mn rules. In order to maintain in stock class I am limited to 17" vacuum @ 1000RPM and cast iron heads. therefore with that said I am @ 420HP and 500+ ft/lb. there is much more potential in these wonderful engines.
Old Apr 8, 2007 | 06:44 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Hipo blocks besides thicker cyl walls also had the HD crank saddle area and extra support ribs on the main bearing saddles. The 352HP was the first performance designated FE block. These engines also used the small chamber C0AE-D hipo heads. Chambers are like the new Glidden chamber heads...sorta peanut shaped. Guess Ford had a pretty good design back then..only to be reused today in performance castings.
G.
Old Apr 8, 2007 | 09:32 AM
josh85's Avatar
josh85
what do you mean by saddle area
Old Apr 8, 2007 | 09:52 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Where the crank sits inside the block. That's the crank saddle area of the block. If you put a HD and std FE block side by side the difference is pretty clear to see.
Old Apr 8, 2007 | 10:14 AM
josh85's Avatar
josh85
I did notice that the main bearing caps are smaller than the FE 360 caps that are out in my truck right now. Also the bolt heads are a 3/4 socket where the 360 are a 13/16
ford_maniac-68
Feb 9, 2017 06:35 PM
boingk
Oct 2, 2016 07:48 AM
F150Torqued
Modular V8 (4.6L, 5.4L)
May 10, 2015 12:09 PM
mitchdowd24
Nov 22, 2014 12:09 PM
coacholy
May 1, 2003 01:20 PM
