I have 2 questions
Old Apr 5, 2007 | 05:56 AM
66chevelle's Avatar
66chevelle
I have 2 questions
Hello everyone I live in Indiana and the weather got down to 32 degrees yesterday and my 2000 F350 wouldn't start it took me about 10 minutes before it would finally fire. I would crank it over and then let the "wait to start light" cycle again and then try again. Is there any way to tell if this is just a relay or if my glow plugs are going bad?
My second question is has any one here sent just there stock PCM to have tuned. I know that DP Tuners has different settings but I am not sure which way to go. My truck is a highway driver 5 days a week and then on the weekends I pull anywhere from 3,000lbs to 18,000 lb trailers.
Thanks for all your guys help I know I haven't posted here allot but every time I do I get really good feed back and I appreciate all of the help I can get.
Old Apr 5, 2007 | 06:11 AM
Randy Pederson's Avatar
Randy Pederson
To check the GP relay you can try a voltage check at the 2 large posts 1 should always have power and the 2nd should have power when the Wait2 start light comes on.This relay fails very!!! often it's about 60$ Can. at a NAPA. The other way to check-it is to short the 2 large terminals for about 10-15 secs. before starting (with the key half-way on) if it starts bettor then the relay is probably at fault.
Let me know how it goes .
Old Apr 5, 2007 | 06:16 AM
Randy Pederson
PS. if the relay doesn't have power at the primary post it could be a bad connection. Check all elect. connections before buying parts.
just another truck's Avatar
just another truck
if you do a search you will find the pin out of the glow plugs as well. My opinion of having your PCM sent out, you are then commited, and there is no way back. where if you buy a programmer, you can go back to your stock settings if need for troubleshooting, service, ect.
Old Apr 5, 2007 | 06:17 AM
just another truck
by the way, any pictures of the chevelle?
Old Apr 5, 2007 | 09:52 AM
66chevelle's Avatar
66chevelle
I don't have any yet I will get some as soon as it worms up. We are having flurries right now so she is under the cover in the garage.
Old Apr 5, 2007 | 09:56 AM
Randy Pederson
Thats right!! keep the chebby under cover . The FORD can take a bit of weather.
