EFI to CARB
This is my first time posting and I'm new to this process so bare with me. I have a Production 1988 460 engine I beleive its the D9TE series. My question is if I use a carb set up to take the place of my EFI, do I have to change the heads if I go with a carb setup on my 88, and if so can someone tell me why. Thanks in advance for the knowlege.
Greg from CT
Interesting question. You will need to post it in our tech forums since this one is used for introductions and you won't find the expert help here. Click on the Forums tab at the upper left and browse over the boards. I suggest trying this one: https://www.ford-trucks.com/forums/forum72/ The 460 forum may also interest you: https://www.ford-trucks.com/forums/forum53/
Good luck!
