1978 - 1996 Big Bronco
Bronco 1987 overheating
Old Oct 7, 2001 | 05:55 PM
tecnomika's Avatar
tecnomika
I have a 1987 Bronco, about to embark in a trip from Arlington, VA to New Mexico (1800 miles). I made a test run this weekend and put 850 miles on it, at an avergae speed of 65 mph. No problem with the temperature on the road, but when I pull into a gas station or stop to take a break, the temp will just go to the red line. This can't be normal, so if anyone has some advise...? Thanks.
Old Oct 7, 2001 | 06:46 PM
JBronco's Avatar
JBronco
Sounds like the fan clutch is bad. To check it, go out to the truck after it has been parked overnight and the engine is cold. Spin the fan around, if it spins real easy and goes around more than once, the fan clutch is bad and will cause overheating at idle.
Old Oct 8, 2001 | 12:22 PM
tecnomika's Avatar
tecnomika
Thanks, will try that. No problem here finding cold nights these days...
Old Oct 8, 2001 | 06:57 PM
honney's Avatar
honney
You can also check the fan clutch when hot, it should just provide more resistance. Not a bad idea to check it when hot and cold so you can get an idea for both, if you detect no difference something's wrong. Just for grins also grab a blade and try to push/pull it fore/aft. If there's ANY play the clutch is bad (assuming it's not fan bolts or water pump). I suggest this because this is what happened to mine last spring - obviously it had been technically "bad" for some time before it got to this point, but the truck never ran hot. The only thing that clued me to it was the screech at start-up and idle sometimes; I happened to grab the fan while looking for the source of this noise and I could push/pull the blade about 1"!
BTW, it was the original fan clutch - 11 years ain't bad!
Old Oct 11, 2001 | 01:28 PM
tecnomika's Avatar
tecnomika
Ok, I did all this and also changed the radiator cap - the sealing rubber was completely worn out. So, this weekend I'll do some test runs, let's see what happens.
Thanks again!
Old Oct 18, 2001 | 12:53 PM
NitrousAl's Avatar
NitrousAl
Thanks guys, you just saved me a ton of money. My '83 Bronco is doing the same thing. It may have blown a head gasket, but I'm not sure. I thought the squealing I have been hearing might be the belt slipping. Never did I think of the Clutch fan assembly being the problem. I replaced the radiator, hoses and thermostat, but the truck still pukes steamy, hot coolant into the overflow container. I plan on junking the clutch fan assembly and stepping up to an electric fan. Thanks again.
Old Oct 29, 2001 | 07:07 PM
83Bronco's Avatar
83Bronco
[font size="1" color="#FF0000"]LAST EDITED ON 29-Oct-01 AT 08:08 PM (EST)[/font][p]I wouldn't over the look the water pump if I were you NitrousAl. The bearing in it could be on its way out of not already there.
Old Feb 17, 2002 | 06:51 PM
87 bronco's Avatar
87 bronco
How well does the electric fan do if you go mudding? Will it short out and then be strannded their of will it do ok in the mud? I've been looking at these and the parts store dont know what they will do in the mud anyone know?
Thanks Austin
Old Feb 17, 2002 | 07:38 PM
Bull's Avatar
Bull
IHateCommieCars
Aug 18, 2014 09:35 AM
Markiv
New Member Introductions
Mar 11, 2014 10:47 AM
eldridgeshelly
Jan 18, 2014 06:51 PM
